Toposurface / site modeling - making openings in the hill
Message 1 of 12
I have project of the building placed under the hill and I needto make openings in the toposurface (something like sketch below - sorry about the quality). Is there any option to make it without using 3dsmax? Can somebody help and suggest something? Thanks a lot.
Replies (11)
Message 2 of 12
Avaris.
Message 3 of 12
It's like a cave, I know how to make horizontal modifications using pad but I've never made vertical openings in the toposurface.
Message 4 of 12
I'm assuming its something like this your trying to achieve? This has been done with a building pad at the back (to create the cut) and a regular floor at the front (to create the overhang) this method will only work if its a surface structure if you've got more underground it might be a bit more difficult...
EDIT: Underground! the much more complicated way! 🙂
Message 5 of 12
Additional surface over the top?
Message 6 of 12
Thanks for reply, unfortunately it's more like underground window 😞 Is there any possibility to make it in Revit?
Message 7 of 12
Oh great idea, it should works. Thanks a lot!!
Message 8 of 12
Is this something like what you're trying to achieve?
Message 9 of 12
Is that just done with a mass and a void @barthbradley?
Message 10 of 12
Variable thickness floor. Shape edited.
https://www.youtube.com/watch?v=PJHKts9QqIw
Message 11 of 12
yeah the variable floor option seems to be a pretty good one too, certainly cleaner as its all one object that your cutting into.Capture.JPG
Message 12 of 12
Yes, that's excatly what I'm trying to do!
