Copy/Monitor IFC - Copier/Controler IFC
1 ANTWORT 1
Nachricht 1 von 2
761 Aufrufe, 1 Antwort
Hi all, AUTODESK,
The copy and monitor Tools (copier/controler in french) is fantastic. However when working with other softwares like ARCHICAD, there is no way to copy and monitor objects from an IFC.
Is there a way Autodesk can develop a plugin to do that? that doesn't seem complicated with the API.
Damien
1 ANTWORT 1
Nachricht 2 von 2
Luiscko
als Antwort auf: Anonymous
For the moment there is no way to do that i hope for the new version you can Copy/Monitoring IFC element but i think so it could be a utopy because is no a native element and this is the principal reason why you can do right now.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
