TOPOsurface Extend
1 REPLY 1
1315 Views, 1 Reply
TOPOsurface Extend
Hello.
1. I have created a toposurface and would like to increase its depth as per the images attached so it goes deeper than the foundations.
2. I would like as well so create a void or something similar so toposurface doesn't go inside the construction.
Help would be much appreciated. Thanks in advance
TOPOsurface Extend
Hello.
1 REPLY 1
The depth of Poche is controlled in the Section Graphics section of the Site Settings dialog accessible from the Model Site panel.
To get the void you need, you would have to create a "Building Pad," which is also available on the Model Site panel.
