Toposolids contour lines
reNQGQS
reNQGQS
Hello
I've tested toposolids on a couple of projects now a they are all complaining about the accuracy of the toposolid. In this example I created a toposolid from a dwg. As you can see there are a lot of inaccurace here. Is there a way to solve this? And why does it happen? This wasn't the case with topo surfaces.
reNQGQS
Hello
The problem is that it simplifies the terrain so pieces of the terrain are missing. The grey lines in the picture are dwg lines. This is parts of the terrain that are left out.
vitorbortoncello
This is a current issue, and I hope Autodesk comes up with a solution soon:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Inaccurate-toposol...
Only around 500 control points are considered in the toposolids. That reduced number of points modifies the input topography and makes the topography very unrealistic. With Toposurfaces we previously had 50,000 points.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
reNQGQS
Yes, that makes sense. I really hope they resolve this soon. Thank you for your help!
