hi there,
I wonder if someone might be able to work out how I can display my house and topography correctly on plan level.
I want to see the Topography and House fully in Level 1 and Level 2. I have attached 3D, and West Elevation. I tried VG and turned everything on.
I am guessing it might be View Range, I played around with settings but still cannot get Topography to appear in full (green) and house to appear. Perhaps you can suggest height in mm I should try that might work. [ note the House is an linked revit file though that should not impact topography in any case ]
Thanks if anyone has any thoughts. Files below.
H
hi there,
H
Solved by dzanta. Go to Solution.
on the site plan, go to view range and set the upper limit to infinity and the cut plane to be higher than the roof. If necessary, adjust the bottom of the primary range to be level 1 and the view depth to the bottom of the site topography
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Thank you so much for taking the time to reply... Worked Perfectly !!
glad to hear...
fyi...do see a button for clicking "accept as solution?" I do not see this button...
glad to hear...
