Topography error
Topography error
nikol_geo
Message 1 of 24
Topography error
nikol_geo
i want to make a topography in revit using SPECIFY POINTS FILE command.
the .cvc file has 3 columns with numbers( 1. X coordinates, 2.Y coordinates, 3. elevation value)
when i try to import the file the below error message appear.
do anyone know how to fix this?
Replies (23)
Message 21 of 24
nikol_geo
Also, how you made the csv file?
What i had done wrong?
Message 22 of 24
syman2000
I use Point Manager lisp to extract the data
http://lee-mac.com/ptmanager.html
I've reconfigure the CAD drawing to make the point read the Z value. Also I move the UCS position closer to the property line point so Revit is able to accept the value. See attached.
Message 23 of 24
nikol_geo
Oh my god, thank you very much!! That worked! thank you!
One last question, how did you manage to reconfigure the CAD drawing
Message 24 of 24
syman2000
Since the point don't have Z value, I use this LISP routine to translate the text to points. Then use point manager and it will translate to Revit.
https://freecadtipsandtricks.com/index.php/2018/12/21/convert-text-to-points-with-elevations-by-data...
