Topography error
23 ANTWORTEN 23
GELÖST
Nachricht 1 von 24
nikol_geo
3283 Aufrufe, 23 Antworten
Topography error
i want to make a topography in revit using SPECIFY POINTS FILE command.
the .cvc file has 3 columns with numbers( 1. X coordinates, 2.Y coordinates, 3. elevation value)
when i try to import the file the below error message appear.
do anyone know how to fix this?
Beschriftungen (1)
23 ANTWORTEN 23
Nachricht 2 von 24
syman2000
als Antwort auf: nikol_geo
Can you provide the CSV file so we can look at what is wrong?
Nachricht 3 von 24
Try it as a comma delimited text file.  Change CSV extension to TXT extension.
Nachricht 4 von 24
nikol_geo
als Antwort auf: barthbradley
thank you so much !!
Nachricht 5 von 24
nikol_geo
als Antwort auf: syman2000
thank you ! this is the file
Nachricht 6 von 24
syman2000
I've looked at the CSV file and import the data, apparently Revit won't recognized it from my end.
When I open up the CSV data, it shows up as one column instead of the three like the right. Also is there a reason why you have 6.016.227.813? Revit won't recognized this value. It has to be pure number value like the right.
Nachricht 7 von 24
Mohamed-Nassar
you can use Civil 3D file from Civil engineer it's more reliable to create surface or use AutoCAD file that have elevations it can made easily from Surveyor man from site or by Civil engineer
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Nachricht 8 von 24
@nikol_geo: What does this data represent? These are not X,Y,Z Coordinates.  What are they?  Care to share?
Nachricht 9 von 24
nikol_geo
 they are coordinates that I had extracted from a topography dwg file
Nachricht 10 von 24
What kind of "coordinates" are they? Obviously this first entry is not an X;Y;Z: 6.016.329.023;40.953.472.142;36.60.
Nachricht 11 von 24
nikol_geo
uuhm.... i don't know maybe i made sth wrong during the dataextraction in autocad?
I will look up to it again
Nachricht 12 von 24
Well, how did you solve it? You awarded a Solution Credit. What was the solution? How were  X,Y,Z coordinates extrapolated from your CSV file?  Neat trick.
Nachricht 13 von 24
nikol_geo
I propably misclicked it. I have to see it again
Nachricht 14 von 24
Post your AutoCAD File. I'll get a Point File out of it.  But, if the topography polylines exists in the dwg, why not just create a Toposurface from Import Instance?
Nachricht 15 von 24
nikol_geo
Because i only have the points from the autocad file, that the topographer had send me.
Nachricht 16 von 24
syman2000
See if this works. I notice the points distance are huge. So I basically set it closer to the centerpoint where Revit can understand. So use the TOPO REVIT-Split.csv
Nachricht 17 von 24
Unfortunately, there is no Z data to extract in this file.
Nachricht 18 von 24
nikol_geo
i think it's wrong... this warning keeps appearing
Nachricht 19 von 24
syman2000
This is why I said to use the TOPO REVIT-split.csv instead of the other. The value is too large for Revit to process.
Nachricht 20 von 24
nikol_geo
It is off scale again.
I don't know why. It makes no sense. Because i have defined the units in meters both in autocad file and revit file.
I'm so grateful for your time @barthbradley , @syman2000
