Topography error
23 REPLIES 23
Message 1 of 24
nikol_geo
2465 Views, 23 Replies
Topography error
i want to make a topography in revit using SPECIFY POINTS FILE command.
the .cvc file has 3 columns with numbers( 1. X coordinates, 2.Y coordinates, 3. elevation value)
when i try to import the file the below error message appear.
do anyone know how to fix this?
Labels (1)
23 REPLIES 23
Message 2 of 24
syman2000
in reply to: nikol_geo
Can you provide the CSV file so we can look at what is wrong?
Message 3 of 24
Try it as a comma delimited text file.  Change CSV extension to TXT extension.
Message 4 of 24
nikol_geo
in reply to: barthbradley
thank you so much !!
Message 5 of 24
nikol_geo
in reply to: syman2000
thank you ! this is the file
Message 6 of 24
syman2000
I've looked at the CSV file and import the data, apparently Revit won't recognized it from my end.
When I open up the CSV data, it shows up as one column instead of the three like the right. Also is there a reason why you have 6.016.227.813? Revit won't recognized this value. It has to be pure number value like the right.
Message 7 of 24
Mohamed-Nassar
you can use Civil 3D file from Civil engineer it's more reliable to create surface or use AutoCAD file that have elevations it can made easily from Surveyor man from site or by Civil engineer
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 8 of 24
@nikol_geo: What does this data represent? These are not X,Y,Z Coordinates.  What are they?  Care to share?
Message 9 of 24
nikol_geo
 they are coordinates that I had extracted from a topography dwg file
Message 10 of 24
What kind of "coordinates" are they? Obviously this first entry is not an X;Y;Z: 6.016.329.023;40.953.472.142;36.60.
Message 11 of 24
nikol_geo
uuhm.... i don't know maybe i made sth wrong during the dataextraction in autocad?
I will look up to it again
Message 12 of 24
Well, how did you solve it? You awarded a Solution Credit. What was the solution? How were  X,Y,Z coordinates extrapolated from your CSV file?  Neat trick.
Message 13 of 24
nikol_geo
I propably misclicked it. I have to see it again
Message 14 of 24
Post your AutoCAD File. I'll get a Point File out of it.  But, if the topography polylines exists in the dwg, why not just create a Toposurface from Import Instance?
Message 15 of 24
nikol_geo
Because i only have the points from the autocad file, that the topographer had send me.
Message 16 of 24
syman2000
See if this works. I notice the points distance are huge. So I basically set it closer to the centerpoint where Revit can understand. So use the TOPO REVIT-Split.csv
Message 17 of 24
Unfortunately, there is no Z data to extract in this file.
Message 18 of 24
nikol_geo
i think it's wrong... this warning keeps appearing
Message 19 of 24
syman2000
This is why I said to use the TOPO REVIT-split.csv instead of the other. The value is too large for Revit to process.
Message 20 of 24
nikol_geo
It is off scale again.
I don't know why. It makes no sense. Because i have defined the units in meters both in autocad file and revit file.
I'm so grateful for your time @barthbradley , @syman2000
Forma Design Contest
Technology Administrators
