Topography affecting shadow on building in elevation
1 REPLY 1
mullarch
127 Views, 1 Reply
I am using Revit 2022 and have come across a problem I have never seen before.  The shadows on the building are fuzzy and very strange when I turn my elevation to realistic view.  When I hide or delete the topography, the shadows go back to normal.  I have played around with the ground plane thinking perhaps the sun is trying to shine through the topography, but it makes no difference.  I can not think of anything else to try...I have never had this problem before with the topography affecting the shadows on the building.  Please note - this question is not about shadows being cast on the topography, it is about the shadows that are on the building that become all messed up unless I hide or delete the topography...very strange.  I have opened other jobs and there is no problem, so it is not a graphic card issue. First picture is with topography hidden, second picture is with topography on.
1 REPLY 1
in reply to: mullarch
If it is a model specific issue then can you share the model?
Forma Design Contest
