Titleblock Parameters dependant on Sheet Parameters
4 REPLIES 4
DanBuck
260 Views, 4 Replies
Hi all,
I have recently inherited a file that used checkboxes in the titleblock family to display the status (first image), but also relys on that same status code to be input into the Sheet parameters (shared parameter) for the automated file naming process (second image). Is there a way I can get the Titleblock family checkboxes to update according to the sheet status, or vice versa. I don't mind complex if/and formula, but I just can't seem to get the Titleblock family to acknowledge the sheet information
Example: when the Sheet Status sheet parameter says D2, I want the corresponding Titleblock checkbox to be selected.
4 REPLIES 4
rxi.gg
in reply to: DanBuck
Seems that it would be possible with dynamo
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
You can create the Y/N shared parameters for sheets instead of titleblock.
DanBuck
in reply to: ToanDN
Will this not still require 2 manual inputs; the checkbox and the status value?
I'm trying to streamline so that only 1 input is required
Actually you don't need 2.  You can use the y/n to drive the same formula that I use for titleblock label for a calculated parameter in a schedule.
Forma Design Contest
