title block trouble
6 REPLIES 6
spoonkim
412 Views, 6 Replies
title block trouble
Hi
I am trying to create my own title block. As you see the picture below, when I change the "width" to 600 it pushes the line to the right. Then I have to move the block names to the right which is inconvenient. Is it possible to move the line to the left when I change the width parameter instead of dragging the ref line?
6 REPLIES 6
azad.Nanva
in reply to: spoonkim
Make group with reference lines and Align that as attachment.
spoonkim
in reply to: azad.Nanva
Thanks for your reply.
That's a nice trick.  I guess it's not possible to move only to the left.
azad.Nanva
no it is not, if it is usefull use Accepted Solution,thanks
Pin the right border line.
TripleM-Dev.net
Hi @spoonkim,
Yes it's possible to keep the right in place and have the left side move.
Only place a reference plane on the right side and delete the one on the left side. (should not need to pin the right ref. plane)
Attach the width dim to the right refplane and the left titleblock line (and constrain any element that should be kept aligned to the right)
- Michel
ps. Also make sure the reference plane is never outside the titleblock bounds, it's reported size will else be off, and could misprint depending use print settings.
spoonkim
in reply to: TripleM-Dev.net
Hi @TripleM-Dev.net
That's good one too! Not sure why it works though. 🤔
