Dimension irregular walls
16 ANTWORTEN 16
Nachricht 1 von 17
tonytwok
875 Aufrufe, 16 Antworten
I'm looking for advice on dimensioning walls of variable thickness. As you can see from the screenshots I started from the right wall with an aligned dimension and then added the subsequent points with the Edit guide lines command. However, by doing this the odds are completely off the table. Isn't there a possibility of blocking the position?
Tags (1)
16 ANTWORTEN 16
Nachricht 2 von 17
als Antwort auf: tonytwok
Are any of the walls perpendicular?
Nachricht 3 von 17
tonytwok
als Antwort auf: barthbradley
None of the walls is perpendicular.
Nachricht 4 von 17
Why? Is it an as-built or are you planning its construction?
Nachricht 5 von 17
tonytwok
It's the model of an existing building lidar surveyed.
Nachricht 6 von 17
The question still remains; why do you need to dimension it?  Are you building the construct?
Nachricht 7 von 17
mhiserZFHXS
Are the walls actually off-perpendicular, or was the lidar slightly inaccurate? Even if they are only slightly off, is it worth not just modeling so its clean?
Nachricht 8 von 17
I agreed with @barthbradley .  We only dimension new to existing, not within existing.
With that said, you can use TAB to use wall intersection points, not wall faces, to witness the dimensions.
Nachricht 9 von 17
Nachricht 10 von 17
tonytwok
Because I'm doing a restoration and I need precise dimensions.
It's simpler build a model exactly from cloud points instead adjust wall and have false dimensions.
The questions is why Revit's dimensions doesn't are simple like AutoCAD are?
Nachricht 11 von 17
tonytwok
als Antwort auf: mhiserZFHXS
Walls are not perpendicular because the building is old, survey is really accurate.
Nachricht 12 von 17
tonytwok
These are coordinates, not dimensions
Nachricht 13 von 17
Yes, I know. That's how I'd plan it and lay it out and build it - using coordinate points.  It's not novel.  Many constructions are planned and built that way.
Nachricht 14 von 17
I don't know what you are talking about or comparing between Revit and AutoCAD. You can certainly dimension your askew walls by TAB-Selecting the corner points, but what value are those dimensions on paper to the contractors in the field?  They're worthless.
Nachricht 15 von 17
One other point:
You are working from a LIDAR.  That LIDAR doesn't reflect the framing of the structure. Just what is attached to the framing.  I'll bet money it was framed level and plumb originally.  It may still be level and plumb. How old is this building?
Nachricht 16 von 17
tonytwok
The building is 50 years old, at the time it was possible that the walls were not perfectly square. Furthermore, the perimeter walls on the upper floor coincide with the lower ones, so if I had had to square the walls I would only have created measurement errors.
Why so much precision? Because here in Italy the law allows a measurement tolerance of 2% and when you survey the building it is necessary to write the dimensions of each element.
So, going back to the beginning, dimensioning irregular buildings with Revit is quite complex, furthermore very often the dimensions from corner points go wrong later for no reason, this bug is very frustrating.
Nachricht 17 von 17
 I don't know what the frustration is at your end, but there is no "bug".
Here's a screenshot of pentagon sides dimensioned in Revit using both Aligned and linear Dimension Styles.
Here's a screenshot of that Dimensioned Revit Pentagon Exported to AutoCAD and dimensioned using AutoCAD's Linear and Aligned Dimension Styles.  The white dimension are AutoCAD's.  Magenta belongs to Revit.
Note that the dimensions values between both are identical between both.  1/256" precision!
Are you using TAB-Select to cycle to end points when placing dimensions as I mentioned in previous post?  Are your Snaps turn on (Manage Tab).
