Door Family - Nested leaf family rotating when it shouldn't
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
herraizYWVDX
270 Aufrufe, 3 Antworten
Hi there!
I'm new here and having huge problems to building a door family, specifically the door leaf.
The family is built with some nested subfamilies (frame, hardware, leaf etc).
There are two almost similar nested door leaf families, one for the elevations and plans (with 3D elements for the elevations and 2D info for the plans) and one for the 3D views (with 3D built elements).
The latter should open with an angle constraint parameter associated with a reference line to which the outer face of the nested door leaf family is aligned and locked.
Up to this point, everything works like a charm but the problems come when we add the second family of door leaves, which should bring the graphical information for the elevations and floor plans.
The new nested doof leaf family ist not associated to the reference line or the angle parameter, but when I change the latter, both leaf families rotate with the same rotation point when only one of them should react.
Rotating nested familiy
new leaf added. No rotation wanted
Change of angle in the parameter
Uploaded video with the problem.
Hope you can help me, thanks in advance!
Rubén
Beschriftungen (4)
3 ANTWORTEN 3
Nachricht 2 von 4
Mike.FORM
als Antwort auf: herraizYWVDX
When you placed the second nest door family, did you still have the work plane set to the ref line being used for the door that you want rotated?
Reset the work plane to level 1 and then place the family.
Nachricht 3 von 4
azad.Nanva
you have reference line I think, the leaf family is automatically lock to reference line .
Nachricht 4 von 4
herraizYWVDX
Savior, that was it!
The little small things...
Thanks a lot!
