Tiles: rendering vs realistic issue
Message 1 of 35
I have this issue with Revit 2017 that i could not solve in all possible ways.
The material itself has 30x30 cm relief to show as ceramic tiles.
In realistic view it shows right (check image ss2) while in render it shows weird (check image ss)
I have tried changing material asset and changing material and using image bump instead of tile bump and still the same issue.I made sure 2 floors are not overlapping and not any other floor is overlapping in other phases. i tried as well auditing the file and checking online for solutions there are none.
Please get back to me ASAP. THanks!!
Replies (34)
Message 2 of 35
In your material setting, be sure that your image size, bump, and relief pattern are following the same scale and positioning.
If you find my post is interesting, I will Appreciate it if you give a Kudo.
If it solves your problem, please click Accept Solution.
Message 3 of 35
Everything is correct, as you see in realistic it shows correct and in normal situations realistic reflects rendering..
I've been using revit fully for my work for 5 years and this is the first time i get this problem.
The material has no image but only a bump since it is ceramic and in the material editor the preview is right.
You can check the attached image
Message 4 of 35
Can you assign the material on a piece of wall or floor, copy paste it to a new file, and upload it?
Message 5 of 35
there might be a deviation in the material joints line when you did the bump setting from the material editor
Message 6 of 35
So you are saying the file is corrupt?
Message 7 of 35
Smate have you tried to see if there is a possibility to a duplicated floor , you might have two floor one under the other .
or if you can copy the material and upload it it will be great to make an examination of the file .
Message 8 of 35
Yes I have said in the original comment I made sure there are no duplicate floors and again the realistic shows right which is usually what should render. Okay I will upload the file in a bit.
Thank you!
Message 9 of 35
Here is the model guys
Message 10 of 35
hello i just checked your model , there is no problem in your file even in the model itself , i tried that in a new project and it is the same thing , the best solution for now is to use a ceramic tile photo for the pattern i have attached this material to this message in addition to the initial file 6630-bump.jpg
Message 11 of 35
This is very odd, nothing is working.. i tried the image from (alyrashid) as a bump as well but still the same. I copied the floor to another file and still the same!
maybe i need an uninstall and reinstall for revit
Message 12 of 35
hello
i tried to render the floor on my station and it works well , have you tried to work on the file i sent you not only the image ?
Message 13 of 35
hello
Regards ,
Arch Aly Rashid
ACI , BIM coordinator
If you find my answer is helpful feel free to give me kudos and if it is the right solution do not hesitate to mark it as a solution . Thank you
Message 14 of 35
Hi there,
Yes i have tried using your file to render and the same issue happened. check the attached image
I do not see any other option as to uninstalling revit and reinstalling..
Any other ideas?
Message 15 of 35
please can you upload the file ?
Message 16 of 35
I already uploaded the file before in a previous comment
Message 17 of 35
yeah i know i mean the new one where u are using the image bump
Message 18 of 35
Here you go.
I even uninstalled revit and reinstalled still the same problem
This is driving me crazy! no matter how i change the material it does the same thing!
Message 19 of 35
It is happening to all materials by the way! even the ceiling i am creating a "tile" bump within revit and the same thing happens...
Message 20 of 35
If you ever look at the OOTB tile appearance asset, they do not use the Tile procedural option for Relief Pattern, but a Tile image.  See the revised file attached.
