Tiled Roof
10 REPLIES 10
Message 1 of 11
tmccar
726 Views, 10 Replies
Tiled Roof
I have created a roof using Model-in-place and creating a Mass on the plane of the roof pitch. Then I used "Divide surface" and "Rectangle" with the tile family,  to give me the individual tiles. Is there any way to stagger the alternate rows in a brickwork pattern?
Labels (1)
10 REPLIES 10
Message 2 of 11
RDAOU
in reply to: tmccar
@tmccar
Use a half step pattern (See GIF Below)
Alternatively, if for some special reason you need to keep the pattern rectangular, model the tile as 2 staggered tiles in the family
Message 3 of 11
tmccar
in reply to: RDAOU
When I run "divide surface" on the mass, Rectangular seems to be the the only pattern that will accept the tile family. The others are just surface patterns.
Message 4 of 11
RDAOU
in reply to: tmccar
@tmccar
The Pattern you set in the Tile family... In the Project, all you need to do is select the mass and apply the Pattern based Tile family you loaded... Follow GIF in previous reply
Message 5 of 11
tmccar
in reply to: RDAOU
I don't see the gif, sorry
Message 6 of 11
RDAOU
in reply to: tmccar
@tmccar
Open forum in Google Chrome or Edge >>> Click on the image in reply 2 >>> it will play a gif recording which has all the steps you need
Message 7 of 11
tmccar
in reply to: RDAOU
I still don't see it
Message 8 of 11
RDAOU
in reply to: tmccar
Nonetheless I am attaching it as a file for you to download
Message 9 of 11
tmccar
in reply to: RDAOU
Thanks - got it.
Message 10 of 11
tmccar
in reply to: RDAOU
Would  it possible to cut a rectangular hole in this  roof?
Message 11 of 11
RDAOU
in reply to: tmccar
You can by
1. Either edit tze mass and cut it with a circular void form
2. Or use a face based generic model with a void that cuts the host in the family.
