Tile view won't show content
Message 1 of 12
Hello there. It's my first time to post in this Forum.
I have just installed Revit 2019. when i tile view on any project I can't see the content inside. everything just disappears as shown in the screenshots. However, Tab viewing is working fine. I don't what specifically is the problem. I changed the resolution of the screen but didn't work. I also want to note I am working on a single screen.
Replies (11)
Message 2 of 12
and the views are zoomed to fit?
Go to you View Tab=>Windows and toggle between Tab and Tile Views. Anything happening?
Message 3 of 12
Yes, I tried zooming to fit. Also if you notice the navigation bar is disappeared when tiled viewing.
Message 4 of 12
ZE....
Message 5 of 12
Navigation Bar Visibility is controlled under User Interface. Are you saying it gets "unchecked" when you tile?
Message 6 of 12
yes it is checked plus i tried to reveal the hidden elements
Message 7 of 12
Strange.
Are you working with 2 monitors? Extended Display?
Message 8 of 12
No, only single.
Message 9 of 12
I will just continue using 2018 version until there is update or sth . thank you
Message 10 of 12
Unfortunate. Perhaps @Viveka_CD should be made aware of this.
Message 11 of 12
I am waiting.
Message 12 of 12
So it shows the information when in tabbed view....but not in Tile View?  Sounds like a video card issue to me.  What happens if you drag the window to another screen?
For now the easy solution is....don't use Tile View.
