make area cover the walls
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1762 Aufrufe, 4 Antworten
I am making areas in a plan. I dont want the walls to show(as in image1). The area cover Everything(as in image2).
I couldn't find the parameter to make the area do that.
rgrds
Tags (1)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Wireframe.
Nachricht 3 von 5
als Antwort auf: barthbradley
if I use the wire frame no wall will be seen any longer. I want the wall to be seen but covered with area color.
I tried transperant but it didn't work.
Tags (1)
Nachricht 4 von 5
Change Color scheme location to Foreground.
Nachricht 5 von 5
ConstantineC
@ToanDN Thanks, I found it here in Properties palette
