how do I make things not show up yellow. Anytime I put up architecture families or generic families up they come up yellow.
Solved by barthbradley. Go to Solution.
@tessilly85 wrote:
I think it is just the floorplan
So what you show is a floor plan with shadow? Share the project file here.
@tessilly85 wrote:
it is any family I put into it
It is very clear that there is only one yellow thing in the picture above, the rest is not. What is it specifically?
@tessilly85 wrote:
The walls are yellow, the generic models are mustard yellow?
Just share the model.
It is yellow even if view template is off as well. I just have a meeting from 10:00-11:30 I will be working on projects the rest of the day and should also say this is for setting up a template.
@tessilly85 wrote:It is yellow even if view template is off as well.
FWIW: Toggling View Template from a named View Template to "none" doesn't turn off the overrides.
Emily Howald is inviting you to a scheduled Zoom meeting.
Topic: revit support
Time: Dec 13, 2022 02:30 PM Pacific Time (US and Canada)
Join Zoom Meeting
https://us05web.zoom.us/j/xxx-xxxxxxxx?pwd=ZHJzVlFzT1Yvbm1ubTFOVVJkcGh3dz09
Meeting ID: 867 3785 7150
Passcode: D1H5Hf
If you are available or whenever. It would be greatly appreciated.
