Message 1 of 32
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hiii Geniuses,
kindly solve this....
Mohamed Arshad K
Software Developer (CAD & BIM)
Hiii Geniuses,
Howard Munsell
hi
I have a same issue with the thick line.my problem is when I converting the drawing to pdf the line turns out too thick.
I also tried to one and off the thin line but it doesn't work. i also tried the visibility graphic and change the line weight to 1 even that it doesn't work. it is really frustrating I don't know what to do .
Try using Microsoft Print to PDF instead of Adobe.
I too faced your issue, like you I use an external application PDF24 creator to convert PDF,
So it also makes lines too dark and then I change my Printer to Microsoft, My problem gets solved.
So try it once.
I did but no it doesn't work .
Change Scale and try it, because sometimes, scaling also makes drawing lines too dark.
now The line weight is a bite pale
Hi
you mean i should changed the scale again ?
Keep your old scale size and change line weight.
Hope this helps!!
Change Line weights according to your scale size.
Check below link once
https://revitpure.com/blog/13-tips-to-understand-line-weights-in-revit
Thank you it's better than before but still look little greyish .
Follow below video. If it solve your problem don't forget to Accecpt the solution.
Thank you.
hi again
I have follow your instruction but still the same .
