The length of ramp
The length of ramp
GHASEM_ARIYANI
Advisor Advisor
Message 1 of 12
The length of ramp
GHASEM_ARIYANI
hi
How we calculate  length the surface slope ramp in revit?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Replies (11)
Message 2 of 12
sureshchotrani
What lenght you are looking exterior, interior or center?
Actually you can draw a line use command LI, use pick option for exteior & interior. For center you can use option offset.
Once draw when you select line you will get the lenth of line in properties:)
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Message 3 of 12
GHASEM_ARIYANI
I mean  is slope surfaceٍ
not Sketching Mode.....
Message 4 of 12
GHASEM_ARIYANI
The length of slope  surface Is different with Length the flat.
Of course Calculate the required length of ramp curve.
Message 5 of 12
L.Maas
Louis
Please mention Revit version, especially when uploading Revit files.
Message 6 of 12
L.Maas
If you want to verify.
Created a sweep at the outer edge (used profile of 100x100 mm)
Created a sweep at the inner edge (used profile of 100x100 mm)
You see when selected the volume is 0.089 m3 (thus length 8.9 m)
Outer sweep was 0.153 m3 (thus length 15.3 m)
Center length would be (15.3+8.9)/2 =12.1
Louis
Message 7 of 12
GHASEM_ARIYANI
Hi
Thank you for your good response
Can this formula to determine a schedule.
Message 8 of 12
GHASEM_ARIYANI
with Method Global parameters in the project i did in the Revit Kepler.
Message 9 of 12
GHASEM_ARIYANI
I think the formula is wrong، Maybe I'm wrong.
The flat length surface is Greater of the length surface slope.
Is it correctly ؟؟؟
Message 10 of 12
L.Maas
The formula is correct. If you look at my screenshot you see that it mentions 12138 mm. In my calculation I find 12132 mm. So a difference of 6 mm.
This is possibly attributed to some rounding along the way. Also my second method of using sweeps gives a result if 12.1 m.
Thus I do not see any mistakes
Louis
Message 11 of 12
GHASEM_ARIYANI
Hi
I think second method is true.
What is the problem The first method For me??
Message 12 of 12
David_W_Koch
You are using 1.3 and 3.3 as the d and D diameters, but your diagram indicates that these numbers are the radii.  D should be 6.6 and d should be 2.6.
Also note that the formula is only calculating the horizontal projection of the spiral.  You still need to determine the sloped length; if you know the overall ramp height, you can take the square root of the sum of the squares of the height and horizontal length to determine the sloped length.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
