Creating new local file
Message 1 of 11
I am trying to create a new local file from a centarl revit file since I got a new Desktop.
IT was able to transfer all my files but my local file did not transfer properly.
When I am trying to create a new local file, it gives me the message below:
What type of network problem are we encounter? Our server and conections are working properly. I need technical support
Veronica Vera
Replies (10)
Message 2 of 11
What is the full path to your local folder?
Message 3 of 11
Do you mean the central path on my computer?
H:\Projects\MIami Office Renovation 2015\Revit:
B&A Office Renovation Central
Hope this is what you need
Message 4 of 11
No. I already saw the central path from your 1st post. I am asking for the LOCAL path, where your local file would be saved to.
Message 5 of 11
It could be saved in the same folder, next to the central.
thanks,
Message 6 of 11
Keith_Wilkinson
yes, if the path for your local file is inaccessible I.e. a drive that is no longer exists then this might be the cause of your problems.
Check that first and if necessary set it to a local folder ( we typically just have ours set to the documents folder)
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Message 7 of 11
There is no "could be".  It is defined in Revit.  Can you look it up and tell us?
Message 8 of 11
IT came and change the path to my local documents. You were correct, the path was going to our administrator.
Thanks for your help!
Message 9 of 11
Keith_Wilkinson
Can you select Toan's post as the solution please so folk know it's dealt with?
Cheers
K.
Maimonides
Message 10 of 11
Message 11 of 11
arrowrah
A better solution is to have a local path which is not user profile specific.
We use C:\Revit for all the standard setups.
This is done using the deployment and Revit.ini files.
