The families are not loading
anis.123
anis.123
I model a family and when I load it in the project , it wont load. No error occurs. This problem occurs occasionally. It is also solved automatically. But I want to know the reason why it some times does not load.
Screenshot may help you understand my problem.
Sahay_R
Can you see the family in the Project Browser? If you do, you can drag it into your drawing. Alternatively if you click on Architecture >>Component you should be able to insert the family.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
