Hi Autodesk community, does anyone know why this would happen in revit on a surface book. The icons/toolbars/properties windows all look as they should, but all schedules and object snap symbols are super tiny and compressed. Please help if you have this issue or know of a fix. I have tried all different combinations of resolutions and scaling without any luck.
Chris
FYI.
Revit 2017 LT
Microsoft Surface Book
screen resolution 3000 x 2000
scaling 200%
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
I have tried all different combinations of scaling and resolution changes without noticing any change to the image that I have linked. it just makes make is bigger or smaller, the squished text always remains the same size.
Hi @Anonymous
Which version of Revit are you using?
Let us know if you were able to resolve your issue.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
