The Elements of O-Level are at the same time elemets of the -1-Level
Hi, everybody.
My problem is that in the -1-Level Plan I have the same elements as in O-Level. I didn't plan them, I didn't copy them, I created -1 level to be just a foundation with a height of the level -0,80 CM. It worked for some time, but after a while I've noticed that in the -1 level I see actually 0-Level.. Wenn I try to delete elements in -1 Level (no matter which of them - walls, furniture, doors), they disappear also in the ground floor (O Level). When they are away, I can see that my foundation "walls" are still there, but before deleting they are not visible. All of the elements are "active", they a not halftransperent as one could think. Somebody any ideas? I would be so grateful for ur help.
joe_keogh
Hi @Anonymous
you should have a look at the View Range of the 2 Plans.
Remember you are in a 3D Model, when you are seeing a wall in one view, it is the same wall as in another view.  Deleting a 3D element from one View, will delete the element from the model, and therefore, from all other views.
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
ennujozlagam
try to check your underlay and set to none and adjust setting of your view range and see if helps. thanks
@Anonymous wrote:
Hi, everybody.
Huh?  I'm getting dizzy.  Let's clarify something first.  Do you actually have two separate Levels in Elevation/Section for the "-1-Level" Plan View and "0-Level" Plan View that you are referencing above?
Thank you, Joe, that was it! I just had to change a cut plane in the View Range.
Thank everybody for your ideas, have a nice day 🙂
