Window in Reveal
Window in Reveal
RJK42
Window in Reveal
RJK42
I have a large reveal in my walls and when I have to insert a window, the trim sticks out as far as the original wall thickness and not up against the wall within the reveal.  Any easy way to adjust this?  Please see attached image. I am using Revit 2109.
Is that an OOTB Window? Check to see if it has an "Inset" Parameter.
...That probably won't do it. Just checked. But this one will. I modified the stock "Fixed.rfa" to include a "Frame Inset" Parameter. Check it out. If that does the trick, modify your Window Family the same way.
..FWIW: it might be easier to embed a wall of the proper thickness instead of using a reveal to cut away wall.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
RJK42
Thanks for the family - what version of Revit did you use to create the familiy?
