Hi, everybody.
My problem is that in the -1-Level Plan I have the same elements as in O-Level. I didn't plan them, I didn't copy them, I created -1 level to be just a foundation with a height of the level -0,80 CM. It worked for some time, but after a while I've noticed that in the -1 level I see actually 0-Level.. Wenn I try to delete elements in -1 Level (no matter which of them - walls, furniture, doors), they disappear also in the ground floor (O Level). When they are away, I can see that my foundation "walls" are still there, but before deleting they are not visible. All of the elements are "active", they a not halftransperent as one could think. Somebody any ideas? I would be so grateful for ur help.
Gelöst! Gehe zur Lösung
Gelöst von joe_keogh. Gehe zur Lösung
Hi @Anonymous
you should have a look at the View Range of the 2 Plans.
Remember you are in a 3D Model, when you are seeing a wall in one view, it is the same wall as in another view. Deleting a 3D element from one View, will delete the element from the model, and therefore, from all other views.
try to check your underlay and set to none and adjust setting of your view range and see if helps. thanks
@Anonymous wrote:Hi, everybody.
Huh? I'm getting dizzy. Let's clarify something first. Do you actually have two separate Levels in Elevation/Section for the "-1-Level" Plan View and "0-Level" Plan View that you are referencing above?
Thank you, Joe, that was it! I just had to change a cut plane in the View Range.
Thank everybody for your ideas, have a nice day ![]()
