- Mute
- Permalink
- Report
When I attach a point cloud in Revit (2017), this message appears: The coordinates of the points in the point cloud file(s) you are trying to import are larger than 30000. When I perform a search for this message, nothing's found. Would be handy to know how to fix this. So my first attempt was to retrieve the origin of the point cloud. So I opened it in ReCap and there's a grid showing the origin. But there are no numbers. I.e. I can't get the coordinates of the origin. Next thing is loading the point cloud in AutoCAD. AutoCAD doesn't show a grid nor origin. So I just picked a point and noted it's coordinates. Then in Revit, I changed the coordinates for both Base and Survey point to reflect those I had looked up in AutoCAD. Next step is again linking the point cloud in the Revit project, using 'Auto - Origin to Origin'. Same message appears and the point cloud is nowhere to be seen. I ran out of ideas?
Simon
