What’s the best way to set up combo design options? If you have a morning room that is part of one design option set and a family room extension that is part of another design option set, what’s the best way of showing the combo art of these two options that is different from the standalone option art. I’m working on a project were I need to show many different option combos rendered from the 3D view.
What do you do if the option configuration is different when the two options are selected together from the standalone version? Maybe when you select the family room extension and the morning room together a wall is removed or a door in the morning room moves further up the wall.
So basically you are overlapping Option Sets. Try not to let that happen by adding another Option Sets to take care of the overlap. For the example you said, I would create another Option Set to take care of the removed wall or the relocated door. For the view, you just have to pick one way or another, or create another view showing different options for the door and the wall.
Therefore, there is no good way of doing this. I have a home design that has many different elevations that affect other options. It seems like a lot of work to add all these options into one option set and have to build out all the options because it’s affecting a good portion of the standard plan.
