Texture of the rebar
12 REPLIES 12
Message 1 of 13
chix88
643 Views, 12 Replies
hi , i have black rebar , they don't look like 3DScreenshot_3.png, don't know why , any help
the render is at realistic
detail level Fine
12 REPLIES 12
Message 2 of 13
in reply to: chix88
Message 3 of 13
chix88
in reply to: barthbradley
thank you for your answer , but nScreenshot_7.pngScreenshot_8.pngothing changed , i tryed the yellow color but still the same
Message 4 of 13
in reply to: chix88
Scroll down to "Tint" and apply a color.
Message 5 of 13
chix88
still the same thing
i thing it has somthing to do with light, you can see the color on the top of the rebar , but it's just too dark,
i don't really need any special color , i just want it to look brighter than it is right now, the default setting will be fine
Message 6 of 13
in reply to: chix88
Is your view phase Filter set to Show Complete?
...just to be clear, you are viewing REBAR Unobscured; right?
Message 7 of 13
in reply to: chix88
You may have another Override acting on the Rebar that is higher up the food chain...
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-D...
Message 8 of 13
chix88
for the phasing it's on "show complet"
i dont't really undertand what do you mean by unobscured but i tried to change the material to another one and it worked
but i have to change it from the edit type, and in that case i have to edit all the types of my rebarsScreenshot_11.pngScreenshot_12.png
tried to use the same material in he Object styles but it doesn't make any change
Message 9 of 13
in reply to: chix88
Message 10 of 13
in reply to: chix88
Just post you file here as an Attachment to a reply post.
Message 11 of 13
chix88
ok thank you
Message 12 of 13
in reply to: chix88
Message 13 of 13
chix88
Thank you
