Top Railing & Floor Extension are not joining
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
aznil_zuhil
279 Aufrufe, 3 Antworten
Hi, I'm trying to create a railing on little staircase with curvy path. It's actually a simple railing with extension posts at both ends to the floor. But the extension post is not joining. I tried to edit the profile and seem the path for profile is continuous, but the profile does not lie on path same as the top rail. Any suggestion on resolving this?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: aznil_zuhil
One way is to edit the rail profile and set the origin to center instead of top.  Or share your model here if you want to keep the profile as is.
Nachricht 3 von 4
aznil_zuhil
als Antwort auf: ToanDN
Didn't know there is a way to set the origin. How actually to do it?
Nachricht 4 von 4
aznil_zuhil
Thank you. I got your idea. Now it's solved!
