Texture Image Material Transparency
2 REPLIES 2
jnbagaleP8GZP
270 Views, 2 Replies
Hi Everyone,
I am having trouble with the transparency of a texture image material.
The Transparency field is supposed to be between 0 and 100. Even a value of 1 makes the image transparent (see the attached screenshot). As soon as value is 10 the image becomes fully transparent.
The image is created at runtime using the Autodesk.Revit.DB.Create(Document document, string name) method and the transparency is applied using the AppearanceAssetEditScope (Floowing https://jeremytammik.github.io/tbc/a/1850_material_level_pixel.html)
Any help is appreciated. The Revit is file attached too if it is useful to check
Regards
Jiva
Labels (2)
2 REPLIES 2
What about Transparency by way of Graphic Overrides in View By Element, By Category or By Filter?
Hi Barth,
Thank you for the suggestion. I didn't know that and it is a good workaround.
However, it will be better if the transparency worked for each object rather than to apply for the whole category.
I wanted to make sure if this was matter of setting the parameters correctly.
Regards
Jiva
Forma Design Contest
