Temporary view template changes when syncing
j0258169
1.892Aufrufe
17Antworten
Nachricht 1 von 18
j0258169
When I have multiple windows open with different temporary view templates applied, and then I sync, all of the windows set themselves to 1 temporary view template.
For example, I'll have three views open. I'll temporarily apply TempViewTemplate001 to one, TempViewTemplate002 to another, and TempViewTemplate003 to the third. Then I'll sync. Then all three views will suddenly have TempViewTemplate003.
Not the end of the world, but a bit jarring, especially when I forget that this happens and I spend a few minutes wondering where things went.
Is this a glitch? Or something wrong with my settings? Corrected in a later update?
On Revit 2019.1
1.893Aufrufe
17Antworten
Antworten (17)
Nachricht 2 von 18
RobDraw
Are these views dependent or parent views?
Rob
0 „Gefällt mir“-Angaben
Nachricht 3 von 18
j0258169
No they're independent, no dependent views.
I think I've only seen it happen on section and 3D views. Not to say that
it doesn't happen on other types.
Nachricht 4 von 18
jagostinho74
same here.
But using Revit 2020.2 with BIM360
Assistant BIM/CAD Manager
Manchester, UK
Nachricht 5 von 18
Acampbell
WE need a fix for this its a really annoying problem
Nachricht 6 von 18
RobDraw
Your request belongs in Product Feedback.
Rob
Nachricht 7 von 18
KooimanBIM
I have the same issue in Revit 2022. Is there already a solution for this?
Nachricht 8 von 18
RobDraw
Do these sections have view templates assigned automatically upon creation?
Rob
Nachricht 9 von 18
pavanyalagudri
Community Visitor
Community Visitor
Same issue can't see any resolution to this
Nachricht 10 von 18
nkiefer-motzengineering
Observer
Observer
the fact that this still hasn't been fixed yet in 2024 shows that autodesk does not care at all
Nachricht 11 von 18
Theo.Volz
I have the same issue and it is incredibly frustrating.  I sync and everything goes wild with the temporary view properties setting.
Nachricht 12 von 18
RobRocks
Really? I don't think so.
Nachricht 13 von 18
RTempleV4GAA
I've been seeing this for years.
I don't use Temporary View Templates, but I regularly use Temporary View Properties. If I EVER use a Temporary View Template, it's automatically added to the Recent Templates list. If I sync with Temporary View Properties applied, Revit will apply one of those Recent Templates. Then, I need to restore the view properties, and redo all of my temporary settings.
This is a bug they have never dealt with. I think ten years is enough, Autodesk. Fix this, already!
Nachricht 14 von 18
RSomppi
Applying temporary view settings should be something easy. If they get messed up, just reapply. The complaints here seem to be exaggerated and would be beneficial in the IDEAS forum as that is where Autodesk is listening.
Nachricht 15 von 18
j0258169
This is not a feature request. This is a big. I doubt Autodesk intended for this behavior to happen.
Nachricht 16 von 18
RSomppi
Don't you think it would be a good IDEA to fix it?
Call it what you want but Autodesk is more likely to address it if you post it in the IDEAS forum.
Nachricht 17 von 18
RTempleV4GAA
No exaggeration, at all. This has been consistent behavior since I started using Temporary View Properties over ten years ago.
It's an old bug that Autodesk has never addressed. Something as simple as a "Clear Recent Templates" option would at least put a band-aid on it.
Nachricht 18 von 18
RSomppi
That sounds like a really good IDEA!
