Temporary view template changes when syncing
j0258169
Message 1 of 18
j0258169
When I have multiple windows open with different temporary view templates applied, and then I sync, all of the windows set themselves to 1 temporary view template.
For example, I'll have three views open. I'll temporarily apply TempViewTemplate001 to one, TempViewTemplate002 to another, and TempViewTemplate003 to the third. Then I'll sync. Then all three views will suddenly have TempViewTemplate003.
Not the end of the world, but a bit jarring, especially when I forget that this happens and I spend a few minutes wondering where things went.
Is this a glitch? Or something wrong with my settings? Corrected in a later update?
On Revit 2019.1
Replies (17)
Message 2 of 18
RobDraw
Are these views dependent or parent views?
Rob
Message 3 of 18
j0258169
No they're independent, no dependent views.
I think I've only seen it happen on section and 3D views. Not to say that
it doesn't happen on other types.
Message 4 of 18
jagostinho74
same here.
But using Revit 2020.2 with BIM360
Assistant BIM/CAD Manager
Manchester, UK
Message 5 of 18
Acampbell
WE need a fix for this its a really annoying problem
Message 6 of 18
RobDraw
Your request belongs in Product Feedback.
Rob
Message 7 of 18
KooimanBIM
I have the same issue in Revit 2022. Is there already a solution for this?
Message 8 of 18
RobDraw
Do these sections have view templates assigned automatically upon creation?
Rob
Message 9 of 18
pavanyalagudri
Community Visitor
Community Visitor
Same issue can't see any resolution to this
Message 10 of 18
nkiefer-motzengineering
Observer
Observer
the fact that this still hasn't been fixed yet in 2024 shows that autodesk does not care at all
Message 11 of 18
Theo.Volz
I have the same issue and it is incredibly frustrating.  I sync and everything goes wild with the temporary view properties setting.
Message 12 of 18
RobRocks
Really? I don't think so.
Message 13 of 18
RTempleV4GAA
I've been seeing this for years.
I don't use Temporary View Templates, but I regularly use Temporary View Properties. If I EVER use a Temporary View Template, it's automatically added to the Recent Templates list. If I sync with Temporary View Properties applied, Revit will apply one of those Recent Templates. Then, I need to restore the view properties, and redo all of my temporary settings.
This is a bug they have never dealt with. I think ten years is enough, Autodesk. Fix this, already!
Message 14 of 18
RSomppi
Applying temporary view settings should be something easy. If they get messed up, just reapply. The complaints here seem to be exaggerated and would be beneficial in the IDEAS forum as that is where Autodesk is listening.
Message 15 of 18
j0258169
This is not a feature request. This is a big. I doubt Autodesk intended for this behavior to happen.
Message 16 of 18
RSomppi
Don't you think it would be a good IDEA to fix it?
Call it what you want but Autodesk is more likely to address it if you post it in the IDEAS forum.
Message 17 of 18
RTempleV4GAA
No exaggeration, at all. This has been consistent behavior since I started using Temporary View Properties over ten years ago.
It's an old bug that Autodesk has never addressed. Something as simple as a "Clear Recent Templates" option would at least put a band-aid on it.
Message 18 of 18
RSomppi
That sounds like a really good IDEA!
