Teacher
3 REPLIES 3
212 Views, 3 Replies
Teacher
Dear sir/ Lady
 We Have a course för Revit and Magicad.
Upp to now we used your GETTINGSTARTED PDF for drawing a house. Last years we used versions 2015, 2016 and 2018. It was ok. This year we use Revit 2020 and we use the same GETTINGSTARTED PDF. I see when I want to run point 15 of GETTINGSTARTED when we want to connect the walls to the roof. When I open 03ROOF floor plan. I can see the underlying walls from lower floor but I can not select these walls. I changed the RANGE BASE LEVEL and RANGE TOP LEVEL but it dose not help. Other students has also experienced this. Can you please give oss some comments.
Thanks in advance
Jan Bijan Pourian
3 REPLIES 3
Either post the Project File or direct us to one so we can advise you.
SteveKStafford
Select Options > Select Underlay Elements
Steve Stafford
in reply to: SteveKStafford
Thank you very much!
Forma Design Contest
