Tapered Roof in REVIT LT
stuart
stuart
Me again!
Trying to create a tapered roof insulation.
Checked variable in build-up dialog. I just don't seem to have that additional box to the right of edit parameter which allows you to add points/heights.
Is this REVIT LT limitation? If so, need a work around.
Are you talking about Shape Editing tools?
...Variable Thickness doesn't work that way.  Read this:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
stuart
I've done all that and the shape editing tool does not appear still.
I am reading old 2014 posts saying REVIT LT does not have them.
I didn't know that. What does Autodesk expect you to do with the "Variable" setting then? That's just plain mean.
Shape editing doesn't work if the roof has any slope.
