Unable to Edit Dimention Length
2 ANTWORTEN 2
Nachricht 1 von 3
292 Aufrufe, 2 Antworten
Whenever I attempt to modify the distance between the exterior wall and the interior wall shown below, it reverts to a measurement ending in 9/16th" and I get the error message you see. For example, if I modify the distance to 9' and hit return I get 8' - 3 9/16" This only happens between those two walls. As you can imagine this is very frustrating. Any help will be most appreciated.
Revit Error.JPGRevit Error 2.JPGI am unable to accurately modify the distance between interior walls.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Reveal Constraints and see if you got any hidden constraints on that wall.
Nachricht 3 von 3
als Antwort auf: barthbradley
Before following your advice, I had closed and opened the file, closed and opened the program, and uninstalled the reinstalled the program. All to no avail. When I saw your reply, I opened up the file and found that it was working fine. Also the wall was not constrained. Strange right!
I'm just beginning to learn Revit, so thank you for the advice, it makes perfect sense and now I know how to Reveal Constraints.
