Tagging camera views in plan?!
eyalbRAPVR
eyalbRAPVR
Is there a way to tag 3D camera views in plan?  It is essential for presentations...
Anyone?
thanks
Not following. What do you mean by "tag 3D camera views in plan"?  Do you mean mark the camera icon location?  Can you elaborate?
ennujozlagam
you can refer to these LINK, LINK  and see if helps. thanks
constantin.stroescu
I'm not sure it this will solve perfectly this problem , so take it more as an exercise....
  • I'll use Dynamo to:
    • create a new Camera View and place the Eye Point on a  known position in Plan View ( use Project Coordinates not Survey)
    • and then place a Family Instance on Eye Point location
    • changing Eye Point coordinates will change ,also the Family Instance ( choose a Symbol for it) location too
Camera in Dynamo for Revit | Revit Products 2019 | Autodesk Knowledge Network
Constantin Stroescu
eyalbRAPVR
Thanks for the Dynamo script. I'll try it. I found an intermediate solution for now but your suggestion seems better.
Thanks!😁
