Tag Customization
Tag Customization
Tag Customization
Hi All,
I have a huge issue creating my tag. The problem is I can't create any instance parameter and I only can create type parameters, please see the image below:
So just to make clear what I mean, I have to create 16 different tag types just to achieve what i want to do in the top image!!!
Can anyone help me find a solution to this and have a single tag with on and off options for parameters. And it should be instance because for every element that I use this tag for, those options may be different.
Make it a single label with multiple parameters instead of stacking multiple labels.
Thanks for the prompt reply, This actually sounds good, so you mean I still have different types of tags but less than 16.
So this way i can reduce it to 5 different types for example, is that right?
