Tag a wall sweep
9 REPLIES 9
Message 1 of 10
1875 Views, 9 Replies
Tag a wall sweep
Good morning. I am trying to tag a wall sweep like I am tagging a wall or a generic model. I saw the response for a previous user but I don't really understand the answer.
any suggestions please?
thanks
9 REPLIES 9
Message 2 of 10
What is your issue specifically?
Message 3 of 10
Create Parts from the wall sweeps and tag the parts.
Message 4 of 10
in reply to: barthbradley
the issue is that the wall sweep does not bcome blue at the time of tagging
Message 5 of 10
in reply to: ToanDN
sorry but I don't understand
thank you
Message 6 of 10
- Select the wall sweeps
- Click Create Parts button
- Load a Part Tag from Library > Annotation
- Tag the Part
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Message 7 of 10
Jerry.jc.Wu
Try paint the sweep and use a material tag
Message 8 of 10
in reply to: ToanDN
Thank you for your response but I cannot find the "Create parts" button
Message 9 of 10
Are you using LT?
Use a Material Tag instead.
Message 10 of 10
You are on LT. Use a material tag or a keynote.
Forma Design Contest
