Sweep under stair
2 REPLIES 2
601 Views, 2 Replies
Sweep under stair
Attached is a screenshot of an issue I'm having with a circular staircase in Revit 2015 LT.
I am wanting to create a gypsum plane under my stairs that extends to the  wall (indicated by grey). I have achieved this by using the sweep tool along the path of the stringer, but am unsure how to "splay" the profile to have it continue to the wall.
Any of y'all have a suggestion?
Mark
2 REPLIES 2
constantin.stroescu
I think that this can be done in Component >Model in Place  using a Sweep ,as you said , combined with an Extrude Void which will cut off the area from the wall on...
(Because you work in LT version the In Place Modeling (extended option) and Conceptual Mass are not available and the Mass method is not to be taken in consideration)
Constantin Stroescu
in reply to: constantin.stroescu
Thank you!
Forma Design Contest
