Attached is a screenshot of an issue I'm having with a circular staircase in Revit 2015 LT.
I am wanting to create a gypsum plane under my stairs that extends to the wall (indicated by grey). I have achieved this by using the sweep tool along the path of the stringer, but am unsure how to "splay" the profile to have it continue to the wall.
Any of y'all have a suggestion?
Mark
Solved by constantin.stroescu. Go to Solution.
I think that this can be done in Component >Model in Place using a Sweep ,as you said , combined with an Extrude Void which will cut off the area from the wall on...
(Because you work in LT version the In Place Modeling (extended option) and Conceptual Mass are not available and the Mass method is not to be taken in consideration)
Constantin Stroescu
