Sweep position is outside of its wall
Message 1 of 15
Hello. I am getting a constant message when trying to place a sweep on a wall when editing that wall. It says it is outside of the wall when in section we can see it is not. Please see screencast.
Help much appreciated.
Replies (14)
Message 2 of 15
Alfredo_Medina
Maybe the sweep is out of the wall, as the error message says. It is difficult to determine that by just watching this brief video.
Message 3 of 15
BIM.Consultant
We can't tell much from the video.
This is off topic but I advise you to only have 1 antivirus installed. I would uninstall McAfee and keep AVG. Computer performance will then improve.
Message 4 of 15
FGPerraudin
Can you send a picture of the sweep?
Or can you just not create it?
Francois-Gabriel Perraudin
BIM management and coaching
Message 5 of 15
@Alfredo_Medina
@BIM.Consultant
@FGPerraudin
Hello. My apologies, I uploaded the wrong video. I reattach.
Thank you.
Message 6 of 15
BIM.Consultant
This is a warning. Warnings in Revit can be ignored. Just ignore it if everything else is going well.
You can attempt to fix it by modifying the origin of your profile. Make the top wraps around wall. You can also check cuts wall to avoid conflicting materials currently there at the top.
Message 7 of 15
FGPerraudin
Re-Hi,
Have you checked the origin of your profile?
It looks like its positionning happens outside of the wall profile, Revit migh mis understand its positionning?
Try to make the origin of the profile appen inside the wall profile.
It should solve the issue..?
François
Message 8 of 15
@BIM.Consultant
Well, things are not going well. Following th error message, the sweep is not created, so I am not having it into the project..
Message 9 of 15
BIM.Consultant
Please attach your file so I can have a look. To have it small size, you can copy paste your wall type to a new project.
Message 10 of 15
@FGPerraudin
1.You mean to go into the sweep profile drawing and check the origin or
2.within the edit wall  - sweeps- distance/ offset
I cannot heavily modify this parameters or I will have the sweep not placed where I want to.
I didn't know this was that difficult..
Message 11 of 15
@BIM.Consultant
Please find attached wall type. Thanks
Message 12 of 15
BIM.Consultant
Set the value of distance to 0 instead of 95 and it will work. You can adjust the profile family to move it up by 95. I have done both in attached file.
Message 13 of 15
ca-at
@FGPerraudinTHIS GUY HAS THE SOLUTION!!
EDIT
THE
PROFILE
AND
GET
THE
O R I G I N
POSITION
INSIDE
THE
HOST...
THE
WALL!
AS FOR @BIM.Consultant - IGNORE WARNINGS?  I'M GUESSING THATS WHY YOU ARE A CONSULTANT?
Message 14 of 15
pierre_derenoncourtAE59H
I had a similar experience.  I duplicated then rename the wall. Profile worked after that.
Message 15 of 15
anniekypoon
I had the same problem and resolved by drawing a section of new wall elsewhere without any connections and return . It should allow you to set up the sweep after that!
