Surface fill pattern has different line weights on different objects
05:03 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Greetings,
I've set up a filter to override and apply a surface fill pattern to different objects (walls, floors, structural columns and structural framing) in the view. However, after the filter is applied, the pattern on walls and floors has a heavy lineweight and the pattern on the columns and framing have a normal pattern lineweight. The normal pattern lineweight is consistent with other patterns in the same view that are not part of my filter.
As an experiment, I tried a model override of all walls applying the same surface pattern settings and the same thing happened. This particular wall family had heavy lineweights, while all the other walls had normal lineweights in their surface fill patterns.
Any suggestions?
