3D view
19 ANTWORTEN 19
Nachricht 1 von 20
807 Aufrufe, 19 Antworten
3D view
Dear All,
When i switch to 3D view its appearing black lines as in this picture. please advice me is there any solution to solve this issue.
Please find the attachment.
Mohammed Sabry
19 ANTWORTEN 19
Nachricht 2 von 20
ennujozlagam
als Antwort auf: Anonymous
Hello, try to delete ur 3D view and create a new one and see if helps, second try to go to options > graphics and untick "use hardware accelerations" and see if helps. Thanks
Nachricht 3 von 20
Diego.Faria
Also, check if your video card driver is up to date.
Diego Faria
LinkedIn
Nachricht 4 von 20
RichConyers
What kind of graphics card/ machine are you running?
How large is the Revit file?
Cheers,
-R.
Nachricht 5 von 20
Can you select it? I mean my first thought is that it's part of a link or something.  e.g. Visibility and Graphics related - not graphic's driver and settings related.
Nachricht 6 von 20
als Antwort auf: ennujozlagam
VG and uncheck Imported categories. See if it disappears.
Nachricht 7 von 20
virgilio_benedictos
check your project base point.. it should be near to the model.
Nachricht 8 von 20
als Antwort auf: virgilio_benedictos
yeah, its near to project model.
Nachricht 9 von 20
Please check my system and graphic options.
Nachricht 10 von 20
@Anonymous: why is this necessarily a graphics card or graphics card settings issue? Both I and @ToanDN gave you another possible explanation above. Could you possibly acknowledge our recommendations and efforts to assist you? It would certainly incentive further cooperation for your behalf.
Nachricht 11 von 20
RobDraw
My first thought was it's a graphics issue and should be ruled out ASAP. I'd feel foolish if I didn't rule that out only to find out it was a graphics issue.
I see something that may or may not be the problem. The hardware acceleration is off and that is a 6G card. I'm no expert I would think that card would be more than capable of utilizing this.
If it isn't a graphics problem, do you have any idea of what is in the model that might be causing this? My first guess is topography but it is too uniform.
Rob
Nachricht 12 von 20
I noticed something in your posted image that may provide a clue: a section box.  Do you by change have a 3D wireframe AutoCAD dwg imported or linked into the project? This could be the culprit.
Nachricht 13 von 20
RobDraw
als Antwort auf: barthbradley
Could you please explain how the three are related?
I have not seen or heard of this before.
Rob
Nachricht 14 von 20
als Antwort auf: RobDraw
Rob,
I’m not sure they are related at all – kind of like I’m not sure that this is a graphics-related issue.
On a second inspection of jshabry’s screenshot, I noticed that a Section Box was in the view and was cropping all the model elements – except for those horizontal streaks.  I just found this odd and it reminded me of something.
Unfortunately, I got nothing for you except this Revit Architecture Forum discussion from 2015:
https://forums.autodesk.com/t5/revit-architecture-forum/revit-section-box-will-not-crop-from-all-sid...
Nachricht 15 von 20
RobDraw
Only time will tell...
If the OP ever comes back.
Rob
Nachricht 16 von 20
Rob, you know what else it looks like to me? A POINT CLOUD RENDERING! Doesn't it to you?
Then again, it could always be a disgruntled co-worker, with a sharpie in hand, going around the office and drawing over all the computer monitor screens! Ha!
Nachricht 17 von 20
Tried this but that won´t work unfortunately.
Nachricht 18 von 20
RobDraw
You've been given several suggestions. In order to find out what is going on here, you need to let us know what you have tried. In other words, you need to help us in order for us to help you.
Rob
Nachricht 19 von 20
RobDraw
Nope, I've already said what I thought it looks like.
Rob
Nachricht 20 von 20
loboarch
This looks to me like a corrupted 3d view. That happens sometimes. Just delete the view and re-create a new default 3d view to replace it.
I don't know all of the reasons why they get corrupted like that, they just sometimes do. Deleting and replacing is a quick and easy fix. if it is happening regularly, then I would start looking at graphics cards, display drivers etc...
Jeff Hanson
Principal Content Experience Designer
Revit Help |
