Structural Framing Visibility Issue
Message 1 of 17
Hi all,
drawing up a model with some custom structural framing and for some reason some of the structural members show and some don't. I cycle through medium and fine detail with no changes, and coarse reverts it to stick. Any thoughts?
Replies (16)
Message 2 of 17
cbcarch
View Range/cut plane?
Workset/Filter visibility?
Try cutting a section and see if all the framing displays.f
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 17
Thanks for the reply. Should have mentioned that phase are all set to new construction and I've tried cyclying through disciplines. They're all at around the same height, so its weird that some sides of the framing are being cut and the other is just invisible. Seems to be doing the same thing in section too. What am I missing?
Message 4 of 17
martijn_pater
The geometry in the family Visibility settings is set not to show in course view. If you select the family, edit family, select the geometry and click Visibility settings you can check/uncheck the visibility for it. This course view representation is a default.
Message 5 of 17
Thank you for your reply, I already checked this out and it is checked for
all detail levels. Any other ideas?
Message 6 of 17
gareth.spencer1
Looking at the image you have shared the don't look like a simple shape. Can you provide some more information about the shape you are trying to create? This way we can understand what it is you need to be visible. Also it does look like the family is curved.
I assume you have. But did you create the family using the Structural Framing family (either Beams and Braces or Complex and Trusses)?
When you have created the family did you set the visibility settings of all the elements and lines correctly?
Please click the Accept Solution button if my reply answers your question.
Twitter: @TheDarkAsset
LinkedIn: gareth-spencer-84202532
Gareth Spencer
BIM Technical Consultant | Man and Machine (UK)
Message 7 of 17
Thank you for replying. Yes this is a custom shape pick-lined from a revolved mass. I have edited a beam family. I've also attached the visibility settings that I have set. going back to my original post I'm unsure why some elements are visible in the floor plan and some aren't if they are all set the same way. I obviously want to show all this information in the floor plan so I need to figure out how to make these elements visible.
Message 8 of 17
martijn_pater
I think it might be a problem with the swept profile for the beam family if you use pick-lines.. or perhaps workplane related... What if you draw it manually instead instead of pick line? You could also make those beams as Adaptive Component which would respond better to curved surfaces.
Message 9 of 17
Ok I'll give that a try. I just found it really strange that some of them
cut and some didn't, even though they are at the same height. Thanks for
your input!
Message 10 of 17
Post your file and start your stop watch. Betcha we have a solution for you in under one minute.
Go!
Message 11 of 17
hehe Stopwatch is started
Message 12 of 17
Voila!
Message 13 of 17
Almost, but you've definitely given me a few ideas to explore, thankyou!
Message 14 of 17
What do you mean by "almost"?
Message 15 of 17
Well the initial issue was that some famiing member were being cut and others weren't. In the example you have sent me none of the members are being cut.
Message 16 of 17
Well then, uncheck "Show family precut in plan views".  The underlying issue is resolved by changing the Cross-Section Rotation.  It's a known and documented issue.  The other issue is that your family is sloppily built.  Whether or not that contributed to your specific issue; I don't know.  Maybe it did. Maybe it didn't.  Regardless, your "circular_column_90" family was improperly built.  I had to fix it because it was bothering me.  I'm surprised it didn't bother you.  Maybe you don't care, but I do -- ALMOST always.   😉
Message 17 of 17
Ok look I'm getting the sense you've taken this somewhat personally. I only wrote "almost" because you didn't actually answer my question, and as you have shown (witihn our multi-message exchange) the real solution was "The underlying issue is resolved by changing the Cross-Section Rotation.  It's a known and documented issue".
The family I built was just modified version of another family, and now that I've rotated the cross-section as you recommended the problem has been resolved and will be fine for all my needs. I appreciate your eventual help, but also no need to be vindictive about someone declaring they haven't actually received an answer in what you have posted, especially newbies.
