how can i access part hierarchy?
Shay.Gaghe
Shay.Gaghe
hi
using revit 2018
i have created a floor object, I want to divide it into 2 separate floor objects so i use Create Parts and i did divide it but now i have no access to the floor properties any more. i would like the give both floor parts a slop but i cant. any idea?
Shay
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
cbcarch
You might be better off creating 2 separate floors.
I don't think it's possible to slope divided parts within a single floor.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
martijn_pater
You could try using modify subelements on the host floor, set parts visibility to show both for the view.
