Structural Beam System in RCP?
jvalaleducation
jvalaleducation
hey - is there a way to get a beam system to show in my RCP?
Right now it's there, but I can't see the beams. Or any beams for that matter. RCP is first, floor plan is 2nd where I can see them.
ennujozlagam
either se underlay or set your view range to bottom and view depth value to negative?
jvalaleducation
My bottom is grayed out and my underlay is already set to none.
Turn on Structural Framing category and set the view to Medium or Fine.
jvalaleducation
yep! For some reason I had it in my head that when I turned on beam system that it inherited structural framing. thanks
mdumaisG7794
I'm experiencing the same issue, but none of the solutions I've tried (including all of the above) have worked. Help!
mdumaisG7794
Never mind, the drop ceiling was hiding them after I'd turned on the structural framing, and I forgot to try hiding it again...
