hey - is there a way to get a beam system to show in my RCP?
Right now it's there, but I can't see the beams. Or any beams for that matter. RCP is first, floor plan is 2nd where I can see them.
Solved by ToanDN. Go to Solution.
either se underlay or set your view range to bottom and view depth value to negative?
yep! For some reason I had it in my head that when I turned on beam system that it inherited structural framing. thanks
