Wall/Door
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
zs-17
740 Aufrufe, 6 Antworten
Wall/Door
Hi
I have joined walls with plaster and cladding. The inserted windows and doors make openings in some walls, but not all of it. The attachment file shows an example of walls without opening. what is the problem and how to solve it?
Regards
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: zs-17
Adjust your View Range.
Like this?
Nachricht 3 von 7
zs-17
als Antwort auf: barthbradley
Hi
The problem still exists. As I know, View Range is for plan view. If you switch to 3D view you can see the sloped window as the example here. This window doesn't appear in section view. The reason is that the window does not make an opening in the layered wall.
Regards
Nachricht 4 von 7
Seems to work here.  Just as I showed in my screenshot above.  I don't know what's happening on your end.   Gremlins, maybe.
Nachricht 5 von 7
zs-17
Ok. Many thanks
Nachricht 6 von 7
lucdoucet_msdl
@zs-17
The problem is with the window family void of "Window-Fixed-Marvin-Direct_Glaze_Polygon_P4-Essential.rfa" was constrained to be thinner than the host wall thickness and isn't cutting in the 3D view either.
When you un-constrain this void object and extend it's faces past the host wall in the family it will expand in width to cut the host wall and attached walls in the project.
Once corrected to cut in 3D, the window cuts the wall when the cut plane is set high enough (±330cm).
-luc
Nachricht 7 von 7
zs-17
als Antwort auf: lucdoucet_msdl
Yes indeed.
Regards
