Strange visual glitch appearing in all my files
EdMilbourn
EdMilbourn
Revit LT
I'm at a complete loss. No problems with any of my files until this morning.
I opened the file for an ongoing project to find a strange, multi-coloured 'plain' with lines radiating from a central point (see attached pic).
It appears to be a plain as when I rotate the view it spins / changes perspective with the model. It is appearing in all views. When I zoom in really close it disappears. I can't select it. I've selected everything and then tried to filter the selection but with no luck. I've printed to a pdf and it does not show up.
I tried some older files (some from 2015) and the same glitch is showing. I was using 2018 but updated to 2019 this morning to see if that helped but the same thing happened.
Would it be a graphics card problem rather than a revit issue?
Any help or suggestions would be much appreciated.
Accepted solutions (3)
Avaris.
You unintentionally downloaded the alienpack for Revit?
Just kidding; I think it is a graphics card problem, rather than Revit.
Maybe you find the solution in this thread.
Did you post about this before? If not, there was a similar thread and screenshot posted on this forum about a month ago.  If I remember correctly, the issue turned out to be that the model was too far from the Project's Internal Origin. I'll see if I can find it and link you to it.
Found it!
https://forums.autodesk.com/t5/revit-architecture-forum/display-error/m-p/8256011#M210168
I'm dubbing it the "Batman Phenom" from now on
EdMilbourn
I was beginning to think it was the Joker but you were right - its the graphics card. I turned off hardware acceleration and POW problem solved.
Thank you.
EdMilbourn
Revit alienpack? I think I'll post that in suggestions.
I turned off hardware acceleration and thats done the trick. No more crazy colours.
aiwalvel
I see you are looking for a translation tool that can help you solve your problem.
Well I may have a solution for you.
Try this amazing AI audio dubbing and translation tool:
https://wavel.ai/solutions/ai-video-translator
The best thing about this tool is that its 95% accurate and is very inexpensive. I tried it myself and was really impressed by the results.
Hope this helped you a little bit.
Happy translating 🙂
